Camaro 01
Hey guys, I'm having a hard time locating my TPS on my 6 cylinder 2001 camaro. I've looked up videos and pictures but to no avail can I find it. Perhaps I'm blind but any set kind of guidance would be appreciated. I just recently replaced my transmission in the car while being told by another mechanic that it's the reason its slipping when I accelerate. Well.... come to find out that wasn't the case after replacing it. I'm having the exact same issue as before. This is a direct quote from some where earlier but it pertains to my exact situation. Any help is appreciated.
No acceleration or RPM increase while pressing gas pedal
asked by Alexandra B on May 24, 2016Hello. My car has difficulty accelerating. There is a loss of power when I try to increase speed. I tried to press the gas pedal all the way, but there is no changes in RPM or acceleration. I had the filters replaced. It would sometimes run normally if I release the gas pedal and press it again. What could be the problem? Thank you.
I'm restoring a 1997 Chevrolet Camaro base model 6 cylinder coupe, two door hatchback. I've replace the brakes and replaced the left turn signal multiple times. When I turn the car on, this is what I see
CHECK GAGES
BRAKE
SERVICE ENGINE SOON
ABS INOP
When I run a Diagnostics, it told me that my 6 cylinder is misfiring. My blower works but my AC don't. When I turn on my left turn signal, the light on the dash stays on, my rear left turn signal in the back stays on, but my front left turn signal doesn't come on. I replaced the bulb 2057 multiple times and the harness multiple times as well. I don't know what the problem could be. Before I do anything else to this car, I want to be sure that it runs properly first. a buddy of mine says that he's considering putting metallic brakes on it so that it works properly. We also had to change out the rear brake cylinder because this one has brake rotors.
If anybody has any idea how to idea how to fix these problems, I would be happy with the help,
Thank you, Shaeffer.
CHECK GAGES
BRAKE
SERVICE ENGINE SOON
ABS INOP
