Turn signal issues
Old Dec 3, 2013 | 07:46 AM
wesman98's Avatar
Default Turn signal issues
In my 1988 camaro the left turn signal either doesn't flash at all or it flashes very slowly. On the inside when I turn on the headlights and the gauge lights come the left signal indicator stays dimly lit up whether I'm using the signal or not. What could be causing this?
Old Dec 3, 2013 | 04:27 PM
blackz87's Avatar
Try replacing the Flasher under the steering column.
Old Dec 3, 2013 | 10:09 PM
GaryDoug's Avatar
When the indicator is always lit, it means that a ground/common is disconnected at the turn/park lamps on that side, usually a bad socket. The current from the parking filament on the left side (in your case) goes through the turn filament to the indicator bulb, instead of going to ground. That is also the reason for the slow turn signal on that side. You probably also have a somewhat dimmer parking light on the left side, as a result.
Victor Lamb
Apr 30, 2013 10:01 PM
lawboy19
Sep 13, 2011 08:32 AM
abestoy
Aug 2, 2009 12:47 AM
bucknakedracin
Oct 10, 2008 12:27 PM
special_k
Oct 20, 2006 03:32 AM
