Turn signal problems...
Old Feb 15, 2006 | 10:13 PM
DublyDurty's Avatar
Default Turn signal problems...
1980 Camaro, 229, V6.
Greetings!
1. Press "hazard flasher" and all bulbs properly flash.
2. Flashers off. Turn parking or all lights on, left front amber (parking) and left front side marker lights both don't work.
3. Lights off. Right turn signals work, left turn signals work "slowly".
4. Replaced turn signal flasher with new unit and cleaned ground connections. No change.
5. Turn lights on. Left turn signal DASH indicator light stays dimly lit all the time even if neither left or right turn signals are on or off which suggests bad bulb. Replaced with new left bulbs. (even though all bulbs flash in Step 1.)
6. Turn lights on again. Left front parking light and left front side marker lamp don't work.
7. Additional information. Last week RIGHT turn signals didn't automatically flash (but worked manually) and RIGHT headlight was very dim. Cleaned right and left grounds and everything worked fine!!!. Three days later, problems suddenly started on left side. (Both headlights are bright.)
8. Suggest possible troubleshooting tips or solutions? I'm stumped!
Thanks,
DD
Old Feb 15, 2006 | 10:37 PM
BLK81Z28's Avatar
Default RE: Turn signal problems...
Just guessing here but go back and check the grounds. Make sure they are all grounded well. Jimmy
1981 Z28 400ci
Old Feb 15, 2006 | 11:40 PM
DublyDurty's Avatar
Will do. Thanks for the quick reply! Any possibility it could somehow be the light switch itself?
Old Feb 16, 2006 | 10:09 AM
BLK81Z28's Avatar
It could be the light switch but bad grounds will cause a lot of strange things due to the way things can back feed and run thru other lights to find a ground ie dim lights and turn sig indacator light dimly lit.
Old Feb 16, 2006 | 06:24 PM
DublyDurty's Avatar
Default Fixed. RE: Turn signal problems...
BLK81Z28 (Jimmy). You were RIGHT ON! It was a bad ground (on the GOOD side...the side that worked fine.) Your "back feed" feedback was what got me to recheck the side I previously fixed. Thanks a million!
DD
Old Feb 16, 2006 | 07:03 PM
BLK81Z28's Avatar
Default RE: Fixed. RE: Turn signal problems...
Way to go man just keep on keeping on! Do yourself a favor and keep that 80 orig and looking good.
1981 Z28 400ci
Old Feb 16, 2006 | 09:34 PM
DublyDurty's Avatar
Again...Thanks man! I owe you a beer [sm=icon_guiness.gif]! (It's my daughter's car and safety is always my number one issue for her.)
DD
Danjo710
LS Series Tech
Oct 16, 2011 03:08 PM
Glzephead
Jan 25, 2011 06:16 PM
robs93z28
Aug 23, 2009 11:09 AM
Blue79Camaro
Aug 17, 2009 09:26 PM
tipdrip215
Dec 7, 2008 05:22 PM
