weird brake light problem
Old May 27, 2014 | 06:05 PM
1bad's Avatar
Default weird brake light problem
If I use my right turn signal my left brake light stops working. Using my left turn makes the left brake light start working again.
Help!
Old May 28, 2014 | 04:03 PM
Tearl99's Avatar
Look into the steering colum wiring for the turn signals. that was my problem I had to replace the hole turn signal wiring system on the colum
Old May 28, 2014 | 04:58 PM
make sure all the bulbs are grounding, ground in the older cars is common fail that leaves the flow of electricity looking for a ground and can so some strange stuff.
Old May 28, 2014 | 05:32 PM
1bad's Avatar
Thank you.
mofioso
May 11, 2015 09:40 PM
2Z's
Jul 8, 2012 12:57 AM
benjamindcox
Jul 18, 2009 11:01 PM
slowZ
Sep 21, 2007 05:28 PM
visualg
Dec 30, 2006 03:44 PM
