Brake light problem
Old Dec 29, 2006 | 08:21 PM
visualg's Avatar
Default Brake light problem
Got strange problem with the left brake light... Seems the brake light doesn't work sometimes, then comes back again, if I mess with the turn signal. So I'm figuring it's the turn signal wiring on the steering column, but don't want to buy it if someone on this forum thinks it could be something else. Yes, the turn signal and the headlights works. It's just that second element on the blub that seems to be problem.. I traced it down to the Yellow wire in the harness, using the wiring diagram, that leads to the turn signal harness. any ideas?
Thanks for everyone's time!
jim
Old Dec 29, 2006 | 11:06 PM
SickSickSick's Avatar
Default RE: Brake light problem
"most" of the time rear bulb problems are loose or corroded grounds. would check that out before i busted into the column. Sick
Old Dec 30, 2006 | 02:22 AM
rat454's Avatar
It's probably the turn signal mechanizm in the colum. depending on the year, it can be a pain to change..the turn signal and brake light share the same wiring. if the mechanism doesn't reset or cancel back to the center position just right or is worn out, you will loose your brake light.
What year is it?
Greg
Old Dec 30, 2006 | 09:40 AM
visualg's Avatar
Greg,
It's a '69 Convertible SS. I tend to believe it's the turn signal wiring as well... If the brake light goes out, all I have to do is trigger the left turn signal and the brake light works again. Do you know if this part is available at Classic or NPD?
thanks for your time,
jim
Old Dec 30, 2006 | 03:44 PM
rat454's Avatar
yes classic lists the turn signal switch assy. 06 catalog page 193
Greg
mofioso
May 11, 2015 09:40 PM
1bad
May 28, 2014 05:32 PM
Tar Heel
Apr 17, 2010 12:35 AM
benjamindcox
Jul 18, 2009 11:01 PM
slowZ
Sep 21, 2007 05:28 PM
