A/c compressor won’t spin
Old May 20, 2021 | 11:35 PM
Jloughry8's Avatar
Default A/c compressor won’t spin
A/c compressor pulley will not spin to the point the engine won’t crank over any thing I can do to free it up or do I need to buy a new compressor or just the pulley
Old May 21, 2021 | 01:54 PM
peterpar's Avatar
You may have a combination of a couple things happening. The AC pulley is the clutch for the compressor. It has bearings that could seize, but I would think if that happened, the compressor should still turn as long as it's not damaged. I would take the belt off and try to turn the compressor by hand. That should give you a better idea if the compressor is seized or not.
Old May 21, 2021 | 09:22 PM
Jloughry8's Avatar
It won’t spin by hand but the car has sat for awhile I just got it a few weeks ago but we can put the belt on it to get it to turn by pulling on the belt real hard but it will rarely make a full retailing before I gotta switch directions it’s been loosening up but it’s mule work
Old May 21, 2021 | 10:13 PM
Sounds like new pump time.
Old May 24, 2021 | 11:57 PM
Corey Jordan's Avatar
Yep needs a compressor. Bought mine like that. You can buy a shorter belt as a TEMPORARY fix, or ac bypass pulley. The short belt puts, imo, too much tension on the pulleys.
Sicilian
Jun 2, 2013 07:54 AM
95camaroaz
Jun 11, 2011 10:37 PM
osduck5
Jul 17, 2010 04:57 PM
TTopCamaro
Jul 6, 2010 03:20 PM
herestolife1000
Apr 20, 2008 02:08 AM
