No a/c system
Old May 16, 2013 | 10:21 PM
Sicilian's Avatar
Default No a/c system
So as i rebuilt the motor and re-installed everything, I felt since my a/c did not work that i didnt have to put it back in, ith that being said I have the compressor in for the belt but the tubes are off, sensors unp[lugged, will this cause an issue?
Old May 17, 2013 | 06:38 AM
MKCoconuts's Avatar
I'd keep the tubes connected to keep dirt out, just in case you plan on fixing it at some point. Other than that, having it disconnected won't cause any major issues.
Old May 17, 2013 | 01:41 PM
Sicilian's Avatar
I have capped the firewall side and the compressor is just dead weight! Thank you for the reply!
Old Jun 1, 2013 | 10:01 AM
bdMoron's Avatar
You can always just remove the compressor all together and do an a/c bypass pulley in its place. Part number is 34202 and its made by motormite. Im running it right now just because my compressor was on the verge of locking up and plus im just going to change all my a/c parts at one time.
Old Jun 2, 2013 | 07:54 AM
Might want to try a search for compressor. I thought there was a theard for deleting the compressor and all you had to do was get a smaller belt. It even listed the the size of belt needed.
Found it
https://camaroforums.com/forum/93-02...l-73336/page2/
Ha, I never followed the thread. Looks like a failure.
camaroguy457
Sep 24, 2011 11:20 AM
Carl Dan
LS Series Tech
10
Oct 20, 2010 05:48 PM
Crunchy
Dec 12, 2008 10:15 PM
ninetysixyenko
Jul 9, 2008 04:55 PM
69camaro1
Oct 11, 2006 03:59 PM
