new compressor or bypass?
Old Apr 19, 2008 | 06:12 PM
herestolife1000's Avatar
Default new compressor or bypass?
95 3.4 V6, car is great, just got it, compressor doesn't work/ burned out(idk really),
i really don't care much for air conditioning in a car(thats just me)
but im wondering, should i get a bypass in place of the compressor, or a new compressor, which would give me better engine performance?
Old Apr 19, 2008 | 06:19 PM
02StanGT's Avatar
Default RE: new compressor or bypass?
If you don't use the air conditioner, then buying a new compressor would be silly. Taking out all the A/C components would give you better mild if any gains, not due to more power, but since it would be a bit lighter. Only reason to put an A/C delete kit in there is if you are going to get rid of everything. Otherwise, just leave it in there. Is it giving you problems even without the A/C on?
Old Apr 19, 2008 | 06:31 PM
nah everything seems to be fine, when i first got it, if i turned on the AC, the compressor smelled like it was burning after a couple minutes, but with the AC off, doesn't the compressor have any resistance? i was thinking a bypass would create the least amount of resistance, thus making the engine do less work
Old Apr 19, 2008 | 06:39 PM
02StanGT's Avatar
With A/C off, the pulley spins freely. Yes, if you were to bypass the pulley, the engine would have less to do. Though the benefits would be minimal.
Old Apr 19, 2008 | 07:49 PM
and what do you guys think of those like 40 dollar cold air intakes on ebay, couldnt i get a generic brand intake and then put on a k&n filter?
Old Apr 20, 2008 | 01:23 AM
skylinrcr01's Avatar
check your freeon level, and if its empty add some with a recharge kit, that could be why its not working, if youd like, a new compressor is ~$200 and can be put on by you. i did mine in my shop all you need is a jack and a few sockets, a ratchet, and a recharge kit. oh and some paitence.
Old Apr 20, 2008 | 01:36 AM
02StanGT's Avatar
I guess you didn't read the part where he said he doesn't much care for the A/C...
Old Apr 20, 2008 | 02:08 AM
MusicMan's Avatar
The Jazz Man
If you find it to be an easy fix, even if you don't like it, try to keep the ac. I didn't want ac in my other car, until I had to drive in 105 degree weather. I got a replacement pump from a wrecking yard for $40 for my bonneville I used to have. It worked just fine. No need to buy a new one, especially if you don't plan on using it often.
87 camaro z28
Jan 22, 2013 04:46 PM
MI_camaro_98
May 7, 2008 09:57 PM
93Z28joel
Oct 28, 2007 10:43 PM
rancho2940
Aug 5, 2007 03:13 PM
parker987654321
82-92 V8 Tech
Jul 17, 2007 04:59 PM
