LT1/LT4 Tech 1993-1997
how do i bypass the air pump
Old Oct 19, 2007 | 02:39 PM
93Z28joel's Avatar
Default how do i bypass the air pump
i have a 93 z28, andi am flashing a code 26 and it is becouse my air pump is shorting out. I was wondering if i can bypass the air pump? i would like to have every thing done and no ses light on. if you can help that would be grate. thanks
Old Oct 19, 2007 | 03:13 PM
Default RE: how do i bypass the air pump
The pump does nothing except for a few minutes after the engine starts. Its purpose is to light up the cat faster. If you remove the pump the cat won't last as long as it should. To kill the SES lite, the PCM has to be reprogrammed to delete the AIR pump.
Old Oct 19, 2007 | 03:16 PM
93Z28joel's Avatar
i dont think you can do that to a 93 ecm or can you i am going to take out the cat and put a test pipe in
Old Oct 19, 2007 | 11:17 PM
It will be simpler & cheape if you just fixed the pump.
Old Oct 21, 2007 | 04:31 PM
93Z28joel's Avatar
ok thanks
Old Oct 27, 2007 | 12:33 PM
93Z28joel's Avatar
$200 for a pump that is crazy does any one know where i can find a cheep air/smog pump
Old Oct 28, 2007 | 12:32 AM
95slvrZ28's Avatar
Junk Yard!
Old Oct 28, 2007 | 10:43 PM
93Z28joel's Avatar
ya that is my next look. i wonder if there are any other cars that have the same pump.
87 camaro z28
Jan 22, 2013 04:46 PM
MI_camaro_98
May 7, 2008 09:57 PM
rancho2940
Aug 5, 2007 03:13 PM
twiz
82-92 V8 Tech
Jul 21, 2007 12:27 AM
parker987654321
82-92 V8 Tech
Jul 17, 2007 04:59 PM
