Bad knocking sound
Old May 15, 2010 | 05:21 PM
  #31
brnyrdanimal's Avatar
FYI, it's probably about time to re-torque the bolts holding your axle in. ANY time you break a suspension bolt loose, it is standard practice to torque it, put a couple hundred miles on and re-torque it. This is due to the tendency of these parts to shift or settle after you hit a few bumps, sometimes a bolt can come loose even if it was torqued to spec to start with, and you don't want that in your suspension.
Old Jun 5, 2010 | 02:02 PM
  #32
Camaroamatuer's Avatar
Yeah i re-torqued those bolts. They installed the wrong fuel pump in the car. But i have yet another problem in the car. The temperature and the oil pressure gauge dont go down when i turn the car off. Also, the voltage gauge is showing that i have really low power. It gets lower everyday and its almost down to 8
stox58
Feb 9, 2014 08:44 AM
DarkrhaveN
Apr 15, 2010 04:58 AM
Rhoshone
Nov 16, 2008 09:09 AM
Andrew*B
Feb 23, 2008 07:43 PM
HOTROD MOMMA
Feb 18, 2008 04:59 PM
