Bad knocking sound
Old May 8, 2010 | 04:02 PM
  #21
Camaroamatuer's Avatar
The pump is new and was installed not too long ago. Im starting to think that maybe they installed it wrong. Im gonna check the fuel pressure next
Old May 8, 2010 | 06:41 PM
  #22
I checked the fuel pressure and everything works properly. Do you know how many gallons the tank holds?
Old May 8, 2010 | 07:01 PM
  #23
so its low and sputtering now? thats when u want to check the fuel pressure. tanks are 15 gallons, at least thats the most ive ever taken. that was outa gas coasting into the station.lol. i think the 97 up have a one gallon bigger tank.
Old May 8, 2010 | 07:23 PM
  #24
Well i found out that it isnt the fuel pump. The tank took about 14 gallons of gas when it was sputtering. It has a full tank of gas right now and the gauge is reading that it has 3/4 of a tank. So now i have to figure out how to fix this gauge.
Old May 8, 2010 | 08:22 PM
  #25
if the sending unit is working right with a full tank u should have 88 ohms at the purple wire from the tank.
Old May 8, 2010 | 08:56 PM
  #26
I have a full tank of gas and im getting a reading of 52 ohms.
Old May 8, 2010 | 10:57 PM
  #27
if the gage is working right it should be a little under 3/4. the book shows 60 ohms at 3/4 and 43 is 1/2 tank. im gona say it got installed wrong or the sender is failing, could be the float or float arm is sticking or hitting against something.
Old May 15, 2010 | 01:57 PM
  #28
Thanks for the help. i think i found the problem. Do you know of any good bonding compound i can use to bond my door skin back to the door itself.
Old May 15, 2010 | 02:18 PM
  #29
so what was the problem? i have used window adhesive and it worked fine. buddy had some left over at his bodyshop. the black color and trying to keep it offf everything made it difficult.
Old May 15, 2010 | 03:04 PM
  #30
http://ecklers.com/product.asp?pf_id=53440&dept_id=127
I'll bet the Gorilla Epoxy glue that you can get at Home Depot will work as well.
