99 camaro hesitates while accelerating
Old Feb 23, 2012 | 03:57 PM
gonziat1999's Avatar
Exclamation 99 camaro hesitates while accelerating
I have a 99 camaro V6 auto, that hesitates when accelerating. It all started a couple of months back, with a check enging light, which turned out to be MAF sensor, replaced it and light went away, the car still hesitated (stumbled), checked fuel pump pressure, was kinda low so i replaced fuel pump along with filter and FPR and new plugs and wires and since i was under the hood went ahead replaced PCV, still stumbled, took it to a mechanic he said it was TPS, went to local junk yard since a new one cost $700, picked up a couple of them cleaned them up tired each one, still stumbles, mechanic checked coils, ICM, said they were good. Could it be injectors, wouldn`t they give me codes? What esle could it be?
Old Feb 23, 2012 | 05:50 PM
JGuy07's Avatar
A TPS (throttle position sensor) is no where near the total you gave. A TPS runs around $40 but that wouldn't be the reason the motor stumbles.
Old Feb 23, 2012 | 11:13 PM
The TPS on my camaro is one whole unit not like the ones on early models, this is a dealer Item. But what them would cause it to stumble?
Old Feb 24, 2012 | 08:23 AM
no injectors do not throw a code. failing injectors should cause a code for misfires though. from what i am seeing the tb has to be replaced to replace the tps. rock has em for 450 bucks
RockAuto Parts Catalog
Old Feb 24, 2012 | 09:02 PM
Thanks for the link,i`ll check injectors first.
gonziat1999
Mar 18, 2012 11:33 PM
Socom
Apr 2, 2010 02:15 AM
Lil Gary
Mar 21, 2010 07:39 PM
98whitemaro
Dec 11, 2007 07:14 AM
foxtrot51
Aug 25, 2007 01:13 AM
