96 v6 5spd any ideas why turning on the AC make it run hot
Old Jul 30, 2020 | 03:16 PM
Matthale's Avatar
Default 96 v6 5spd any ideas why turning on the AC make it run hot
Running hot when AC is on
Old Jul 30, 2020 | 07:49 PM
Most vehicles run warmer with the AC on,even the semi I drive at work has the fan kick on far more often with the AC on.
It's quite a draw on the motor and of course if you have the AC on it's probably hot outside.
Is it overheating or just running warmer than usual?
Old Jul 31, 2020 | 11:13 PM
cwilt's Avatar
Make sure your fan turns on when you turn on the a/c. Also make sure you coolant level is correct...obviously with a cold motor.
androzer
Mar 5, 2013 08:55 AM
jrgearhead
Apr 21, 2011 01:31 PM
meteoralp45
Sep 13, 2007 04:38 PM
jdubs1813
Aug 20, 2007 10:00 PM
fbjunior
May 10, 2007 05:23 PM
