2000 Camaro v6 3.8L Fan Switch Location???
Old Aug 1, 2020 | 01:47 AM
Dillon Atkinson's Avatar
Default 2000 Camaro v6 3.8L Fan Switch Location???
Hello! I am working on a 2000 Camaro V6 3.8L ( 3800 ll series) and my cooling fans are not working, I have tested the fans and they work, the relays are good and fuses are good. I believe it may be the fan switch needs to be replaced but can’t figure out where it’s located. Does anyone know?
Old Aug 4, 2020 | 07:04 PM
bcm controls the fans. gonna need to get a scanner on it and see what the computer is seeing. it may be the temp sensor is not sending the right temp to computer.
Old Aug 4, 2020 | 07:07 PM
go here and download the factory service manual for your year. 2000 svcman https://www.mediafire.com/?40mfgeoe4ctti it will tell you the steps to go through,
bigtylr86
Oct 6, 2010 04:50 PM
kKkInGsRuLeEe
82-92 V8 Tech
Jul 4, 2008 08:53 PM
hshawn31
May 6, 2008 08:55 AM
mysrt4ownsyou
Oct 7, 2004 09:23 PM
mysrt4ownsyou
Oct 7, 2004 07:06 PM
