radiator fan switch
Old May 2, 2008 | 07:11 PM
hshawn31's Avatar
Default radiator fan switch
anybody know where the radiator cooling fan switch is? i got a new one that turns on at 190 degrees instead of 225 degrees, but cant find it on the 'maro. i have an 89 rs t-top 2.8L v6
Old May 3, 2008 | 12:56 AM
sewerrat's Avatar
Default RE: radiator fan switch
I don't think the 89s had a seperate cooling fan temp s/w. I'm quite sure the ecm turns the fans on/off but does get its info from the CTS (coolant temp sensor). If that is what you are talking about then it is next to the t-stat housing outlet(top rad hose)on the drivers side.
Old May 3, 2008 | 03:20 AM
hshawn31's Avatar
napa sold me the switch specifically for an 89 rs 2.9.....
Old May 4, 2008 | 07:11 PM
hshawn31's Avatar
wow...no one knows?
Old May 4, 2008 | 07:15 PM
350rs's Avatar
March 2008 ROTM
the 89 have one. Look on the block. Probably below one of the heads. Mine is on the passenger side below the number 6 cylinder. Get yourself one of those Haynes books. They are a HUGE life saver when you need them. Saved me about 1300 bucks with a heater core change from the dealer. MORE than paid for itself in ONE project
Old May 4, 2008 | 07:36 PM
hshawn31's Avatar
i have a haynes but it doesnt say anthing about the switch. the book doesnt even reference it in the appendix section.
Old May 4, 2008 | 10:19 PM
350rs's Avatar
March 2008 ROTM
really? hmm. Id say just look around for it. prolly on the block somewhere.
Old May 6, 2008 | 08:55 AM
hshawn31's Avatar
found it...in case anybody needs to change theirs its located on the engine block, passenger side right next to the dip stick tube for the oil. its in a really bad place, cant get any tools to it....
Jackie O
Oct 24, 2014 04:15 PM
akleeve
Nov 6, 2010 12:44 AM
bigtylr86
Oct 6, 2010 04:50 PM
drjgarage
Jun 2, 2008 05:46 PM
whoffman
Sep 12, 2006 01:00 AM
