Heating / AC
Today I'm driving through town and my girlfriend is complaining about how hot it is so I decided I would turn on the A/C for her. Well I try to turn it on and get nothing. No air blowing out of the vents at all, not even a minute amount. Tried all different things and can't get the heat or AC to blow air. Any idea what it could be? I checked the fuses and they are all good.
perhaps this might be for you...
http://www.thirdgen.org/retrofitac
i dont know a lot about ac but it might be the compressor.????
It was just recharged. It was working find earlier in the day, then when I tried it again,I get no air blowing out. Hot, cold, nothing... no matter how high I turn it on. It's been converted to R134 or whatever it is. System is fine and free of leaks. I just don't get any air blowing out of the vents.
ORIGINAL: kyleb
does a 95 z28 take r12 to?
how do i check for leaks?
'95 is r134. If you know it's leaking you can buy some ultraviolet dye to put in the system. Run it for a while and shine a blacklight on it to see where it's leaking. If you want to check if it needs recharged, just hook up a pressure gauge to the suction side of the compressor. Auto parts stores have these gauges, and they're simple to use.
