96 camaro 3.8
Old May 22, 2019 | 11:03 AM
Shemar Briggs's Avatar
Default 96 camaro 3.8
Hello I came because I know some of these guys on here are pretty knowledgeable. Well if anyone could help me out I have a 3.8 camaro and when I press on the gas it seems like it seems sluggish when accelerating like something is holding it back. I changed fuel filter recently as someone told me that could be the problem . And I also have a filter on the engine (not stock air box ) could that be the issue ? I had the spark plugs changed about a year ago . What could be the issue car has 180k miles .
Old May 24, 2019 | 10:25 AM
could be a number of things. good first step check plugs to make sure they are all firing, other things, plug wires may be bad, fuel pressure may be low, maf may be dirty or failing, coil may be failing, air filter plugged, catalytic converter may be plugged. Im sure there's more.
RPDRed6
Nov 21, 2012 08:56 PM
xlowes
Aug 4, 2011 04:33 PM
chewybacca11
Aug 23, 2010 06:20 PM
camaroFaST
Jun 25, 2009 05:14 PM
DaveyM
Apr 9, 2008 12:44 PM
