5 speed tranny
Old 03-07-2011, 11:53 PM
carterbrad94's Avatar
Old 03-08-2011, 05:11 PM
3800camaro's Avatar
Ok so I guess I'll change my clutch when I do my intake gasket and all other top end gaskets. So I'm planning on dropping the engine a few inches by undoing the 6 k member bolts is that doing to cause a problem if I remove my tranny with it dropped?
Old 03-08-2011, 05:13 PM
3800camaro's Avatar
Also where is a good place to jack the car up with the k frame unbolted? Is there a place in then front bumper or should I just jack it up at the jack points?
Old 03-08-2011, 05:26 PM
at the jack places is where i do it. one side at a time. i go from side to side so im not jacking it up so far as to take a chance on bending something.
Old 03-09-2011, 08:36 PM
3800camaro's Avatar
then thaats how i'll jack it up. Also can the speed sensor be tuned to accept readings properly from a 3.73 gearing or 4.10 gears? if i remember correctly the 96 pcm cant be tuned so i dont know if that includes gear changing.
Old 03-09-2011, 09:46 PM
Banditz's Avatar
Not sure about your ride bro, but on my t5 out of my third gen, I had the exact same inssue and just crawled under the car and adjusted the pressure screw in..well adjuster or whatever you wanna call it. Sorry, been working on the truck for the last bit so its been awhile since I thought about a five speed...lol. Dunno if your newer t5 has it or not...just a thought.
Old 03-09-2011, 10:01 PM
3800camaro's Avatar
Where abouts was that screw at?
Old 03-09-2011, 10:09 PM
Banditz's Avatar
right next to where the fork goes in bro. But I dunno if the newer t5's have them or not...worth a look though..Drivers side, next to the trans. You can't miss it..its a huge torx bit or somethin like that..maybe allen, been awhile like I said..Sorry wish I could offer up more info.
Old 03-10-2011, 08:20 PM
3800camaro's Avatar
So does anyone known if the 96 speed sensor can be adjusted for different gear ratios? I'm planning on going from my 3.23 to 3.73 or 4.10.
  #20
Old 03-10-2011, 08:22 PM
Banditz's Avatar
Did yo try that? Or even look to see if you do have the screw?
XedLos
09-27-2011 06:04 PM
mpd228
05-11-2009 09:52 PM
yzinger
10-27-2008 09:35 PM
1GR8Z28
06-13-2008 03:13 PM
nebt3x
02-21-2007 05:59 PM
Quick Reply: 5 speed tranny
