4th gen V6 manual trans question
Old Apr 28, 2007 | 04:16 AM
sewerrat's Avatar
Default 4th gen V6 manual trans question
I have an 88 (3rd gen)v6 with a worn out 5spd trans. I quy is selling a standard trans from a 96(4th gen)v6. I'm not sure what engine size it is.Will the 96 V6 trans bolt up to my 88 2.8? Are there any lenth issues? How can I convert the 96 speed sensor trans to run my manual speedo drive on my 88? Thanks for any response.
Old Apr 30, 2007 | 04:37 PM
squisher's Avatar
Default RE: 4th gen V6 manual trans question
Should be the same bellhousing bolt pattern, so the 4th gen v6 trans should at least bolt to the engine (88 I'm assuming a 2.8, in that case the trans from the 3.4 will definitely bolt up to your block. I am reasonably certain that the 3800 shares the same bolt pattern.) I couldn't say if it would fit in the car itself though. Somebody else may be able to chime in for that, or check in the 3rd gen section of the forum and see if anyone else has done it.
JohninIndy
Jun 4, 2014 08:01 AM
kal
70-81 Transmission & Differential
Dec 19, 2010 09:19 PM
suzonda
Sep 25, 2009 02:31 PM
sewerrat
May 3, 2007 12:28 AM
sewerrat
Jan 28, 2007 01:38 AM
