2000 Chevy camaro
Old 07-15-2017, 08:39 PM
Ejofurrall's Avatar
Originally Posted by Gorn
Yes and there is a cable and a learning curve as well the software is very expensive. You could get the GM dealer to fix it for less then a seat of Hptune will cost you.
ok thank you
  #22
Old 07-31-2017, 10:48 AM
kevins88ss's Avatar
You could also do what we did and install a VATS bypass by Painless. Wire it right into the ECM.
https://www.summitracing.com/parts/prf-64023
  #23
Old 07-31-2017, 10:55 AM
Ejofurrall's Avatar
I reset the vats and discovered that the starter is bad so I gotta save up for that part. Thank you for the response
  #24
Old 07-31-2017, 11:28 AM
That system only shows working 1990-1992? are you sure it will work with a 2000? That is a huge jump in tech from the old ECM to a PCM CAN network.
  #25
Old 07-31-2017, 11:33 AM
Ejofurrall's Avatar
my guess would be that it can but would probably need software updates. I did the YouTube steps and worked out for me
  #26
Old 07-31-2017, 01:39 PM
I check Painless website. You posted the 23 part and he would need the 24
https://www.summitracing.com/parts/prf-64024
We should put that link in a sticky somewhere.
jessie18
05-04-2012 06:03 PM
jon_uscg2001
06-13-2010 01:42 PM
Quick Reply: 2000 Chevy camaro
