2000 Chevy camaro
yeah not sure that's an option because I got it from a guy who had the column for two years before I got it
I believe the BCM's have a Vin code it verifies so swapping that out is not an option. The Vats can be programmed out of the PCM by anyone with HPtune but your security light will come on at some point but the car will still run.
is there a special cord that I need to plug in the laptop to run the hptune?
if you havent found it yet, this is a good place to get info on the early 4th gens. 4th Gen LT1 F-Body Tech Aids
#20
Yes and there is a cable and a learning curve as well the software is very expensive. You could get the GM dealer to fix it for less then a seat of Hptune will cost you.
