kinda dumb question....
Old Apr 22, 2007 | 06:52 PM
1983camaro's Avatar
Default kinda dumb question....
in a previous thread i talked about how i got an 88 camaro parts car for my Z28. well today i figured id take the fenders off and the front bumper and ground effects. theres one problem, i guess i cant find all the bolts to un bolt. So i was wandering if someone could give me instructions on how to take the fender off, and where the nessecary bolts are that i need to unbolt. ( i just got the bolts ontop of the fenders unbolted . cant find the rest. I FEEL STUPID lol . im also havig trouble taking off thefront bumper as well. ( im new to this and its my first time )
Old Apr 22, 2007 | 10:05 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: kinda dumb question....
Keep looking. There shouyld be some under the fenderwell near the tires. Also you might want to invest in a repair manual. Sometimes you can get the manual from the manufacturer that has the build instructions in them.
Old Apr 23, 2007 | 02:36 PM
rollermotor's Avatar
you got the top ones, there are also three or four going into the bumper cover on each side, and two on the bottom one going to a brace and one bolting the rear to the body.
Old Apr 25, 2007 | 11:34 AM
uradumass5695's Avatar
There are two bolts on the rear of the fender on the bottom by the doors but you have to take the ground effects off first. They are easy to take off the are just held on by clips. There is also i believe two or three bolts right in front of the tire on the bottom as well. I suggest getting a repair manual first also, they will give you a step by step process on how to fix everything. good luck
Old Apr 25, 2007 | 10:22 PM
1983camaro's Avatar
i finally got the pasenger side fender off, it was a chore lol for being my first time, where those 2 bolts are under the door, i will have to hammer it back into shape. and it was a little rusty so im gonna use a dremel tool to clean it up and primer it .
Old Apr 26, 2007 | 11:36 AM
Ya i had a problem with those two bolts on mine as well. But that car going to the junkyard eventually so i used a hammer when i couldnt get the fender off. It worked.
tattoo400
Jan 10, 2013 05:55 PM
Luz Hernandez
Apr 19, 2011 08:25 PM
shinwolf14
Jun 21, 2009 05:36 PM
IshZ28
Sep 13, 2008 12:41 PM
eskimoobob
82-92 V8 Tech
Sep 20, 2007 08:47 AM
