dumb question ja ja
Old Sep 10, 2008 | 10:00 PM
IshZ28's Avatar
Default dumb question ja ja
if i remove the thermostat from my 94 z28, will the 'service engine soon" light come on?? cause this happens everytime my temp reaches 1/4... thanks in advance
Old Sep 10, 2008 | 11:32 PM
RFxCamaro's Avatar
Default RE: dumb question ja ja
just removed mine today no prob at all
Old Sep 10, 2008 | 11:35 PM
IshZ28's Avatar
hmmm i see, well that means ill have to scan it then...
Old Sep 11, 2008 | 01:12 PM
RFxCamaro's Avatar
i have a scanner and i scanned and got nothing
Old Sep 11, 2008 | 01:16 PM
MusicMan's Avatar
The Jazz Man
Wait, what? You removed the thermostat? Why?
Old Sep 11, 2008 | 01:21 PM
02StanGT's Avatar
ORIGINAL: IshZ28
Why don't you find out what the Service Engine Soon light is wanting you to know, and stead of trying to find a band aid fix so it won't come on.
Old Sep 11, 2008 | 01:31 PM
cbr600rx7's Avatar
This is not a dumb question.[>:]
Old Sep 11, 2008 | 02:44 PM
IshZ28's Avatar
mmm ok, its just that it is weird that at exactly 1/4 temp the service engine soon light comes on... so maybe i was thinking about scanning it
Old Sep 11, 2008 | 03:15 PM
Scanning it would be the first logical step. And I'm gonna say you have a bad sensor.
When the engine is cold, your system is in "open loop" mode, and the engine runs mostly on the ECM's presets. When the engine gets hotter (a little over 100 degrees) the engine's temp sensor (not gauge sending unit) tells the computer to put the system into "closed loop" mode. Now your air/fuel flow is registered and adjusted by all your sensors. By taking out your stat, you're just prolonging the time the coolant takes to get hot, and just keeping the system in "open loop" longer.
Old Sep 11, 2008 | 04:40 PM
meteoralp45's Avatar
why did you remove your thermostat?
