dumb question ja ja
Old Sep 11, 2008 | 06:49 PM
gvmv's Avatar
Default RE: dumb question ja ja
ORIGINAL: meteoralp45
why did you remove your thermostat?
This is a good question. Did you put a restricotor ring in? The thermostat servers another purpose as it slows the water down so it can actually absorb some heat. Not having a thermostat/restrictor is bad for your engine.
Old Sep 12, 2008 | 12:57 AM
ORIGINAL: gvmv
Please elaborate? Whether the water in the block is standing still or moving, there is always water in the block. There's nothing I know of that makes moving water incapable of absorbing heat. The purpose of the thermostat is to hold the water in the radiator long enough to allow it to cool down somewhat. Some cars can actually get away with running without a thermostat and not over-heating, but you're not likely to get away with it on a restricted air flow car like these Camaros. And if it's a winter driven car, you'll never heat up. Running without a stat isn't bad for the engine, unless it causes it to overheat.
Old Sep 13, 2008 | 12:25 PM
IshZ28's Avatar
basically i removed it because i live here in puerto rico and its usually very hot most of the year so i thought it would be better for the car tu run without it... i noticed that the thermostat is 180 and that was weird cause arent they usually like 195 or somethin?? im also thinking that it might be a bad sensor cause after a while the service engine light turns off...
Old Sep 13, 2008 | 12:27 PM
MusicMan's Avatar
The Jazz Man
removing it does the opposite of keeping the engine cool, because the fluid is moving so fast that it can't capture the heat from the engine. A 160 or 180 t-stat would be just fine.
Old Sep 13, 2008 | 12:32 PM
02StanGT's Avatar
Get a scanner and scan it or have it scanned when the light is on. Also, Camaro 69is right. Water has no problem picking up heat, though it may have a problem losing heat without the thermostat (water wouldn't be in the radiator long enough for heat to be removed).
Old Sep 13, 2008 | 12:41 PM
tammy's Avatar
Banned
The computer has a timer in it, the engine has to be warmed up in a certain time for the emmisions to go in to closed loop, if it does not see that within the parameters programmed int he PCM, it will set a code, You need that thermostat anyway, metal wear at its least at 195 degrees.
tattoo400
Jan 10, 2013 05:55 PM
purpl96
Jan 28, 2008 03:08 PM
eskimoobob
82-92 V8 Tech
Sep 20, 2007 08:47 AM
TheWanderer
Aug 20, 2007 03:22 AM
zachyfarms
May 13, 2007 03:23 PM
