Engine swaps
Old Oct 13, 2006 | 01:40 AM
81CanuckZ's Avatar
Default Engine swaps
Has anyone heard of or done a conversion to a modern 5.3L vortech in a second gen camaro? Im thinking about either that or the 4.8L as possibilities. I'll probably buy an older style one that will bolt right in. Unless it's easy to put a newer Vortech in. If it's easy enough i'll probably do it. Just wanted to see if anyone's done it before or knows how difficult it would be.
Old Oct 13, 2006 | 11:33 AM
uncle bill's Avatar
Default RE: Engine swaps
The Vorech will bolt right in. You may have to do some tricks to install the 5.3L LS type engine.
Old Oct 13, 2006 | 01:47 PM
shnormo's Avatar
You need the wiring harness and computer. If you don't use the matching trans, you have to program the computer to think that the trans is hooked up and working.
Old Oct 13, 2006 | 06:07 PM
81CanuckZ's Avatar
ORIGINAL: shnormo
I'll probably be using the Turbo Hydramatic 350 that's in it already. Is it hard to program the computer like that?. Im also curious as to which engine would be better. There's 10HP or difference between the 5.3 and the 4.8 and i don't know the torque numbers offhand. I know the 6.0 is kind of a dog compared to the 5.3. My dad's truck has the 6.0 and my moms old suburban has the 5.3. It's way nicer revving and way smoother than the 6.0. Is there a difference between the 5.3 and the 4.8? I'll probably go with the 5.3 if i do this. Otherwise i'll just buy a ZZ4 350 or a similar engine. Maybe the 330HP deluxe from chevy. Just want to get a few different opinions before i decide on anything. I've never had any experience with the 4.8L so i thought i'd ask here.
98stuntin
Feb 28, 2012 10:07 PM
emptyazureskies
May 4, 2010 09:40 PM
Half_the_halfer
Nov 30, 2009 12:48 PM
clyon
Jul 27, 2008 11:19 PM
JohnyGrimm
Feb 22, 2008 06:41 PM
