305 to 350
Old Oct 13, 2006 | 12:38 PM
84VarinZ28's Avatar
Default 305 to 350
is is possible to bore/stroke a 305 up to a 350? just curious...theyre the same block right? so i thought it would be possible...anyways just let me know somethin...yea
Old Oct 13, 2006 | 01:29 PM
AlfredB18's Avatar
Default RE: 305 to 350
ORIGINAL: 84VarinZ28
Nope. Not the same block, though they can be thought of as such since they use a lot of interchangeable parts.
I think a 305 punches out to a 335 and can still be called streetable.
Old Oct 13, 2006 | 01:44 PM
shnormo's Avatar
The crank, stroke, and camshaft locations are different.
Old Oct 13, 2006 | 03:02 PM
FlufyTiger's Avatar
You can stroke and bore the 305 to a 335 with a 30 overbore and a crank for a SB 400, anything higher would be pushing beyond the limits of that block.
Old Oct 13, 2006 | 03:28 PM
blackz87's Avatar
You can bore it out to 350 ci and have no wall thickness between the bores and other passages. You will have a piece of scap iron.
Old Oct 13, 2006 | 07:36 PM
SickSickSick's Avatar
you can bore to 315 cid and stroke it to a 350. i can give you the info on kit ordering. Sick
Old Oct 15, 2006 | 02:28 PM
84VarinZ28's Avatar
ok thanks guys...yea Sick could you give me that ordering info...thanks
Old Oct 15, 2006 | 10:40 PM
uncle bill's Avatar
The 305 uses the same crank and connecting rods as a 350. The 350 block has a larger bore and larger diameter pistons. The cam and crankshaft locations are the same. I don't know where shnormo is getting his information.
Old Oct 16, 2006 | 01:11 AM
GRIFF's Avatar
I wonder if there would be anything to gain by doing this other than it would be neat to do. What would it take... boring 30 over with a 4 inch stroke. The clearencing would be a job. You would still be limited for valve size unless you used a different head. I dont see an advantage over just using a 350. Also the stock cranks are the same throw but they are different in balance I recently asked my machine shop about using my 305 crank in a 350 and they said it would be cheaper and better to just find a 350 crank because they would most likely need to add mallery to balance it.
