dome light out? temp guage wire... where??
Old 08-05-2007 | 01:51 PM
Pro_built7's Avatar
Default dome light out? temp guage wire... where??
hey guys, a few more problems with the 89 rs here... i checked all the fuses they're good, but my dome light is still out, brand new bulb and everything, what is going on? and also where is the temp guage wire located under the dash what color / which one is it (so i dont have to tear it apart) it was converted to a carb, but now i need my temp guage working, thanks! the dome light is really confusing me tho..
Old 08-05-2007 | 02:43 PM
MadMikeZ28's Avatar
Default RE: dome light out? temp guage wire... where??
The temp wire should be green. You will see it in the plug behind the cluster or in the wad of spagetti under the dash.
Did you check the dome light with both doors and the switch? None of those work? Are the under dash floor lights on? Maybe your door jamb switches are not grounding. Check at the light for power. It should have power all the time. The door jamb switches and head light switch make the ground to complete the circuit.
Shibby
08-17-2009 04:57 PM
daltons 1980
11-19-2007 02:36 PM
Pro_built7
82-92 V8 Tech
08-12-2007 02:17 AM
dnulnarts
06-25-2007 02:33 PM
74Z28
05-26-2007 12:31 AM
