Car bogs down when accelerating..help
Old Sep 6, 2011 | 08:11 PM
alexjohnson105's Avatar
Default Car bogs down when accelerating..help
I have been experiencing problems with my 1986 iroc when i accelerate
-loses power
-does not want to go until pedal all the way down( still doesnt run properly)
-sometimes will kill when i try to accelerate
-hiss from carburetor whenever i give gas,that i dont believe has been there and getting checked out
-sounds terrible
I dont know whats going on and i have changed things like spark plugs and ignition coil and still hasnt resolved it and i have even cleaned the carb with sea foam.
Any ideas?
Old Sep 6, 2011 | 08:20 PM
BasicConcepts's Avatar
Technical User
sounds like you have a vac leak around the carb causing the a/f ratio to be off
Old Sep 6, 2011 | 08:59 PM
I just got a vac hose replaced not to sure about them but i would think the mechanic would have seen that or replaced that, this is a relatively new problem but goes away then comes back. i will give that a look. Thank you
Old Sep 6, 2011 | 09:25 PM
hevymetalg's Avatar
How bout the gasket under the carburetor?
Old Sep 6, 2011 | 09:34 PM
Technical User
That's more what I was thinking... spray some starting fluid around the base of the carb with the car running if it revs you got a leak
Old Sep 7, 2011 | 10:34 PM
Turns out i need to rebuild my carburetor...
Sewperdave
Jun 4, 2013 06:43 AM
Paul86iroc
82-92 V8 Tech
Dec 22, 2012 10:24 PM
xXChipXx
Dec 11, 2010 06:35 PM
PHILLIP JOHNSON
82-92 V6 Tech
Mar 29, 2010 02:46 PM
foofer1986
Jul 29, 2006 07:15 PM
