what is the factory transmission size for a 83
Old Sep 9, 2011 | 08:06 AM
jmiller5058's Avatar
Default what is the factory transmission size for a 83
i need to know what size of tranny came factory with a 83 camaro z28 crossfire injection ? and will a 700r4 bolt in with the same cross member placement ?
Old Sep 9, 2011 | 09:49 AM
Your year Z28 came with either a 5 speed manual, or the 700R4.
Old Sep 10, 2011 | 05:35 PM
djs383's Avatar
I'm pretty sure there were some 4 speeds until 84
Old Sep 10, 2011 | 08:07 PM
In the base coupe, yes. But not in the Z28 (the car in question). Welcome To Camarosource.ca - Internet's Largest Most Complete Camaro Resource Site
Old Sep 11, 2011 | 10:17 PM
would a turbo 350 or 400 bolt into it easy or is there some modding to be done?
Old Sep 11, 2011 | 10:22 PM
There's some modding to be done. Moving/customizing the trans crossmember and lengthening the driveshaft are the major changes. Unless you found yourself a long-tail TH350, then you should get away with just having the crossmember to deal with, as far as fitment issues goes.
Old Sep 12, 2011 | 07:54 AM
djs383's Avatar
There is that option, or put a 700R4 in it, which will work like a champ since that was the trans for most 3rd gen camaros anyways. The beauty of it, is that there is already a crossmember to fit it, and most likely a driveshaft too. The 700R4 is just as strong as a th350....plus you get OD
Mark L
May 1, 2015 08:25 AM
dsinclair999
Feb 21, 2011 11:24 AM
microkid
Dec 20, 2010 08:59 PM
1977 402
Mar 3, 2008 07:56 PM
Puck90a
Jul 21, 2007 02:24 PM
