axle code for limited slip rear end?
Old Aug 19, 2005 | 04:29 AM
sewerrat's Avatar
Default axle code for limited slip rear end?
Hello, Recently got a 94 camaro with a LT1, 4L60E auto. I think It has a limited slip but I'm not sure. If possible, I don't want to remove the rear diff cover because the cover doesn't leak and it looks like the previous owner put some fresh clean oil in. I did jack the rear end up and turned the driveshaft, which I noticed both wheels turned the same direction. I then lowered one of the wheels down on the pavement and turned the other that was still floating. I encountered some resistance but the wheel did spin. I'm not sure if this is a valid test nor do I know if these model came with factory limited-slips? I'm wondering if knows the location and number of the axle code which would indicate a limited slip? Thanks for any replies
Mike
Old Sep 18, 2005 | 09:35 PM
89CamaroGuy's Avatar
Default RE: axle code for limited slip rear end?
all axle codes should be located on the right side axle tube with the code facing towards the front of the car.
hope this helps
Old Oct 26, 2005 | 02:53 AM
sewerrat's Avatar
Hey thanks for the location. I got some numbers right where you said. My numbers are SPL 278...1? Does that sound right, so does that mean it might be a 2.78 gearing? That pretty high for my city driving.
Mike
Old Oct 29, 2005 | 01:34 AM
If you have limited slip, there should be an additional tag attached to one of the bolts holding the the rear cover to the axle. The problem is that many times the tags rust away or gets lost when the cover is removed.
lightningcruiser
May 27, 2012 07:54 AM
Envisi0n91
Feb 5, 2010 08:32 AM
BojanglesBatman
Sep 24, 2009 07:29 AM
Pops 96
Jul 30, 2009 12:21 AM
bbailey4life
May 14, 2006 02:05 PM
