how do i fix this?
Old Jul 3, 2005 | 04:05 AM
Camarok's Avatar
Default how do i fix this?
someone please tell me where i can hook this back up and what its need to be fed through?
Old Jul 3, 2005 | 01:24 PM
JD1969's Avatar
Default RE: how do i fix this?
That looks like the sending unit for an elec. temp gauge. If you had an elec temp gauge in the car the wires should be there, other wise you will need to run wires through the fire wall and just hook it up.
Old Aug 11, 2005 | 11:23 PM
nj02z28ls1's Avatar
its a water sending unit, if you are fuel injected hook it up, if not they sell a plug to cap it off.
Old Nov 3, 2005 | 04:54 PM
TimmyTheWop89's Avatar
ur obviously not fuel injected, seeing that fat edelbrock, but like njo2 said, u can get little plugs to block it off, i did the same.
