Tranny help
Old Oct 21, 2011 | 03:40 PM
carlallen's Avatar
Default Tranny help
Lets see if i can explain this right, i have a 86 iroc z that was tpi with 700r4 well i turned it into carb with a older 350 motor bored 30 over and has a bigger cam in it, so now the question I had to put a stall convertor with my 700r4 and the 700r4 is rebuilt, but still it does what seems like a long shift and when it finally does shift it feels jerky, any ideas?
Old Oct 21, 2011 | 04:14 PM
Cheeks's Avatar
August 2011 ROTM
the cheap and easy fix is bump up the line pressure.
Otherwise, what was done when it was "rebuilt"? Maybe look into an aftermarket valve body, it will help yours shifts greatly
Old Oct 21, 2011 | 04:25 PM
Make sure the TV cable is hooked up, unless the trans was modified to run without it. If you still have the cable, then your issue may be with the differences in linkage geometry between how it was with the TB, and how it is now with the carb. Having the cable operate right is more than how it's pulled out at WOT, where it moves at partial throttle is critical as well. You can't just stick the cable on the carb linkage and call it good. Read this: 700R4 Info Page 1
Old Oct 21, 2011 | 08:24 PM
6SpdZ's Avatar
^x2^
if its the factory trans in the car, then that cable needs to be adjusted. It controls pretty much everything that the trans does.
Old Oct 24, 2011 | 11:50 PM
carlallen's Avatar
What would bumping up line pressure do?
Can you give any info on how to go bout adjusting cable? I bought a bracket that is made for the carb and tranny and it has the throttle spot hook up and the cable that runs to tranny.
WIspartan1026
Mar 25, 2010 09:58 PM
bhoeksema
Mar 6, 2010 08:38 PM
blowncamaro
Oct 12, 2009 09:05 PM
rancheronut
Jul 14, 2009 01:12 AM
mpd228
May 11, 2009 09:52 PM
