clunking rear end - 84 camaro
Old Sep 11, 2010 | 02:07 PM
endo's Avatar
Default clunking rear end - 84 camaro
i have a clunking in my axle. looks like a bushing/bearing is going out.
the gear in the red circle has a lot of play up and down when i hit the wheel or i can wiggle it up and down by hand.
the area in the green circle is where i can see the axle and i can see it move up and down.
any suggestions on fixing this issue.
Old Sep 12, 2010 | 03:13 AM
Where's the "posi rear end" as mentioned in your sig? That's an open diff you have there.
And unless the picture is playing tricks on my eyes, it looks like your bottom spider gear is missing a tooth....or more? That'll certainly cause a clunk.
Old Sep 12, 2010 | 10:17 AM
endo's Avatar
i was told it was a posi but never knew for sure. which gear is the spider gear.
Old Sep 12, 2010 | 10:45 AM
Inside your ring carrier. The two side gears are splined to the axles. The smaller top and bottom ones are the spider gears that turn with the axles. I'm looking at the bottom one, with the tooth facing out. It doesn't look like there's a tooth there.
Old Sep 12, 2010 | 11:18 AM
Looks like the dentist was there. lol
Old Sep 12, 2010 | 11:30 AM
Better pull the gear out, put it under your pillow, and hope the toof fairy shows up tonight!
Old Sep 12, 2010 | 05:13 PM
endo's Avatar
i think it is just the picture. here is another picture. it didnt look like any teeth were missing to me.
Old Sep 19, 2010 | 09:42 AM
endo's Avatar
well im going to start looking for a new axel. what is the range of years that i can swap into my car. also if i find one with disc brakes will i be able to hook my current brake system up to the disc brakes with out any problems.
98camarov6
Sep 8, 2012 02:46 PM
Socom
Jan 6, 2012 12:25 PM
twomanyjeeps
Aug 13, 2011 06:45 PM
endo
Apr 4, 2011 04:18 PM
akohnz
Jun 2, 2006 11:59 AM
