clunking rear end - 84 camaro
2 Attachment(s)
i have a clunking in my axle. looks like a bushing/bearing is going out.
the gear in the red circle has a lot of play up and down when i hit the wheel or i can wiggle it up and down by hand. the area in the green circle is where i can see the axle and i can see it move up and down. any suggestions on fixing this issue. Attachment 32474 Attachment 32475 |
Where's the "posi rear end" as mentioned in your sig? That's an open diff you have there.
And unless the picture is playing tricks on my eyes, it looks like your bottom spider gear is missing a tooth....or more? That'll certainly cause a clunk. |
(Post 454655)
Inside your ring carrier. The two side gears are splined to the axles. The smaller top and bottom ones are the spider gears that turn with the axles. I'm looking at the bottom one, with the tooth facing out. It doesn't look like there's a tooth there.
Looks like the dentist was there. lol
Better pull the gear out, put it under your pillow, and hope the toof fairy shows up tonight! ;)
1 Attachment(s)
(Post 454714)
Attachment 32453 |
well im going to start looking for a new axel. what is the range of years that i can swap into my car. also if i find one with disc brakes will i be able to hook my current brake system up to the disc brakes with out any problems.
