clunking
Old Aug 29, 2012 | 09:41 PM
98camarov6's Avatar
Default clunking
i have a 98 camaro v6 it is clunking in the rear everytime i brake i changed the rear wheel bearing . what else could there be that would cause that
Old Aug 29, 2012 | 11:57 PM
I'm gonna go way out on a limb here and ask, did you check your brakes to make sure nothing is loose/sloppy/floppy?
You replaced one wheel bearing, so let's assume you would have caught something if it was on that side. What about the other side?
Old Aug 30, 2012 | 08:40 AM
98camarov6's Avatar
Sorry i forgot to say i did both
on each side and i made sure all the brakes and everything was good. but i did notice that the bushing for the sway bar are really worn and dryrotted could that be the cause of it
Old Aug 30, 2012 | 09:35 AM
GreenMamba's Avatar
Yep, thatll do it. I started noticing alot of noise at slow speeds going over bumps in my Jeep, and it was worn sway bar bushings. Had them replaced, and never heard another sound out of them.
Could be. Could also be other bushings like the control arms, etc., letting the rearend shift.
You'd want to give everything a good once-over, maybe twice even.
Old Aug 30, 2012 | 11:20 AM
98camarov6's Avatar
Ok thank u its driving me crazy
Old Aug 30, 2012 | 12:38 PM
98camarov6's Avatar
What about the muffler it is really shakey when move it around
Old Aug 30, 2012 | 01:08 PM
go back to the tailpipe and give it a push forward, not a shove, dont want to hurt anything. anyways try to recreate the g force of brakes and see if you get a clunk.
Old Sep 6, 2012 | 06:38 PM
IdriveDSM08's Avatar
also have you checked your u joints? they tend to start making noise when they go bad
Old Sep 6, 2012 | 06:41 PM
Edwardgp's Avatar
Alright what did you find out.
