Rear end clunking
Old Jan 3, 2012 | 09:51 AM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Default Rear end clunking
So I've been having this ongoing issue where my rear makes clunking noises while driving. It sounds like it comes from the axles on each side, but I jacked up the car and made sure the bearings were good and there was no play. I also just put new kyb agx shocks on the rear so that isn't the issue either. This noise has me stumped. Anyone have a clue as to what it could be?
Thanks,
~Socom
Old Jan 3, 2012 | 10:38 AM
Clunking is on acceleration, over bumps or around corners?
Assuming it is over bumps a long pry bar is your friend. You have clearance in one of your bushings. Could be upper control arms, lower control arms or the Panhard bar. It’s a 2 man check with your hand on each above connection pry with a 48”+ bar on the tires. Each of the above parts has 2 places to check both sides. Since your car is higher miles there will be a small amount of play in all the joints. If it is enough play you can hear it while driving the play will be pretty large once you find it.
Old Jan 3, 2012 | 10:42 AM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Well granted I have all tubular suspension on my car and granted it is fairly new, there shouldn't be any play (especially being poly) but I will give that a check anyway. Could be quite possible. And it happens really at random times, over bumps and while driving on flat roads, its not a consistent noise.
Old Jan 3, 2012 | 11:30 AM
You have done the upper and lower control tubular? Does the lower arms have the pivot type bushings in them? As you can imagine as the car tilts the lower control arms need to flex, a tubular control are will not flex so it needs so the forward bushings need to have pivots. If not you can damage the frame where the control are connects.
Old Jan 3, 2012 | 01:47 PM
check your jack to make sure its secure. make sure the gas tank is not moving around. if the pump was changed not so long ago it may not have been tightened right and shifted. check lug nuts to make sure they are tight.
Old Jan 3, 2012 | 04:24 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
If you are talking about the a-arms, then yes, they have a pivot bushing. My rear control arms do not though.
Old Jan 3, 2012 | 04:35 PM
RPDRed6's Avatar
i had a obnoxious loud clunking noise that happened right when i bought my car, turns out it was some part of the exhaust flopping around.
Get down under there and give it a yank ............. to see if its loose
Old Jan 3, 2012 | 08:13 PM
I am talking rear control arms, Are you rear control arms tubular? You did say the clunk was from the rear, I did kind of assume since you used the word clunk it was something you can feel.
Old Jan 3, 2012 | 10:31 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Its more of a knock/clunk that happens randomly while driving. But yes, my whole suspension is tubular. I also forgot to mention that my driveshaft has new u joints so that isn't the issue.
Old Jan 3, 2012 | 10:37 PM
AboveTheLogic's Avatar
You sure its not the transmission mount? I had a clunk that I originally thought was from the rear end that turned out to be the mount.
