Will a turbo 400 transmission work
Old Aug 29, 2007 | 04:06 PM
myproject's Avatar
Default Will a turbo 400 transmission work
I have a 92 Z28. I wanted to put in a 406 but i'm just going to use a built 350. I have the 700R4 transmission right now, but I heard it won't handle alot of power. Plus It's acting like a normal 700R4, floor it and you don't go much faster. I am wondering if a turbo 400 will work in this car and what I would have to change to make it work.
Old Aug 29, 2007 | 05:06 PM
1983camaro's Avatar
Default RE: Will a turbo 400 transmission work
theres high performance 700r4's that you can buy and directly swap. but theyre expensive ( like 700+) you can put a 400 turbo in there but your going to have to modify the car to get it to fit.
Old Aug 29, 2007 | 05:08 PM
MadMikeZ28's Avatar
The 700 is good for 350 HP and TQ. And that is a conservative number. If you go with a 400 you will have to install a torque arm mount , lenghten the drive shafy and modify the cross member. and you loose the low first gear and over drive. The 700 can be rebuilt and made to handle more ponies
Old Sep 3, 2007 | 07:35 PM
mike86rs's Avatar
i have been told that the th400's are pretty strong as they are. i had to have a custom drive shaft, b&m make a kit for it to fit in comes with the tourqe arm mount and the trans mount brackets. so all said and done it cost me about 400 bucks!
camaroteen82
12
Apr 7, 2012 07:30 AM
bvans
70-81 Transmission & Differential
Feb 21, 2011 02:24 AM
damnyanks87
Jan 3, 2008 12:24 PM
434camaro
Aug 28, 2007 09:57 PM
VTownSuzieQ
Nov 26, 2006 08:27 PM
