will stock valve springs work??
Old Dec 14, 2009 | 11:19 PM
ScottD's Avatar
Default will stock valve springs work??
For the ongoing Vortec swap......I plan on putting a .465 lift cam in her. (its about as high as i can go with stock components) A friend of mine said that because of the cam, the OEM valve springs wont have enough seating pressure?????
The springs have 55,000 miles on them and I dont want to replace them if I dont need to. Im already about a jazilion bucks overbudget.
You see what a set of good headgaskets go for??? Cheeeeeerist!
Old Dec 14, 2009 | 11:26 PM
Jr. Mechanic's Avatar
August 2009 ROTM
PM sent.
Old Dec 15, 2009 | 08:00 PM
microkid's Avatar
March 2011 ROTM
Technical User
they physicly will work, but a higher seating pressure will keep the valves from floating and possibly hitting the piston. you would only need the next spring rate up from stock. and a good set of head gaskets shouldnt be more than $50.
i bet you are wishing you did more research before you pulled your motor apart?
marten
Feb 11, 2012 10:39 PM
tbl76camaro
May 14, 2010 08:05 PM
sesopha
70-81 V8 Tech
May 5, 2009 04:24 PM
95camz28
Nov 21, 2007 12:31 PM
joeZ28
Jul 19, 2007 12:18 PM
