Wheel adapter or spacer for C5 wheels
Old Jun 22, 2009 | 09:30 PM
rockoosi1's Avatar
Not the vendor I got mine from, but this is what I'm talking about. This is for a set of four, but I'm sure you'll be able to buy only two from this guy. The ones I got also came with special lug nuts to bolt to the axle. I'll keep looking.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Thanks for the link. Can you remember how thick yours were? I will call them tomorrow and order a pair if I know what size to get.
Old Jun 22, 2009 | 10:44 PM
The ones I have were for putting a set of 4th gen Camaro wheels onto a 2000 Monte, which has a smaller bolt pattern. They are 1" thick. When I scoped out my 3rd gen Camaro to put the same wheels on, I measured the backspacing on the 3rd gen wheels at approx. 5.5" and the 4th gen's at about 7.25". 1.5" spacers would have worked. I never went so far as swapping the wheels over though. It would be best if you measure the backspacing of your current front wheels, and then the C5 wheels to get the difference to determine how thick of a spacer you need. Lay a straight edge across the rim of the wheel on the back side, and measure down to the hub mounting surface to get your backspacing measure.
Old Jun 22, 2009 | 11:55 PM
rockoosi1's Avatar
Good idea. I will take care it tomorrow and post my results incase somebody else is trying to do the same thing.
Old Jun 24, 2009 | 07:22 AM
rockoosi1's Avatar
Well, I measured up everything last night and it looks like I will need an adapter or spacer 2.25" thick to be safe. Since I don't believe I can get lugs that long I guess an adapter will be needed. It is a little thicker than I wanted to use but the guy I called said people are using them as thick as 4". I will let you all know how it turns out. Thanks for all of the suggestions.
PS: Can the spindles be changed to match track of the vettes or the newer camaros....just a thought.
Old Jun 24, 2009 | 08:34 AM
You can double check a different measurement too. Set the C5 wheel in place where it will look like it clears in the back the best, as well as how it fits at the front of the fender lip. Then measure from the back hub of the wheel to the mounting surface on the car. You might not need quite as much, or it will confirm that compensating for the backspacing difference is what you need.
Bas Jussen
Apr 2, 2014 02:44 AM
MadMikeZ28
Jun 12, 2010 01:57 AM
MadMikeZ28
Jul 20, 2008 04:32 PM
microkid
May 15, 2007 11:11 PM
no.1 95camaro
Jan 19, 2006 10:23 PM
