Steering wheel hub adapter
Old Nov 24, 2006 | 09:18 PM
MadMikeZ28's Avatar
Default Steering wheel hub adapter
I was trying to install my Lecarra wheel I got for my 84 into my 91 with the air bag. The stuff does not fit well. The column is bigger and the shaft is a little different. Has anyone installed a wheel on thier 90-92 Camaro that had an airbag? Did you use a billet adapter? How did you make it work?
Old Nov 25, 2006 | 12:14 AM
shnormo's Avatar
Default RE: Steering wheel hub adapter
On my 79, I didn't have an air bag. But the steering wheel adapter was larger than the actual shaft. I took the space our and it still wouldn't hold the shaft tight and it would slip when I turned the wheel to the left. I ended up using castaloy to "weld" the hub to the shaft.
Old Nov 25, 2006 | 04:51 AM
MadMikeZ28's Avatar
I had a grant adapter start to slip on me before. Nothing I want to happen again.
Old Nov 28, 2006 | 07:26 PM
MadMikeZ28's Avatar
Hey come on people, wheres' the love?[&o]
No one here replaced thier aftermarket wheel in thier car that had an airbag? I e-mailed Lecarra and they have yet to answer. I feel so unwanted.[]
Old Nov 28, 2006 | 09:35 PM
shnormo's Avatar
Unhook your negative battery cable. At the bottom of your steering column, there is a yellow signal wire for your air bag, disconnect it. After that take off the cover. Then take off the yellow wire at the top. There are a couple bolts holding the air bag assembly on the steering wheel. Take those off and it should lift right up. Then remove the lock ring and then nut. Then use your steeringwheel puller and take the steeringwheel off. Line up your steeringwheel hub adapter with the switch for the horn. Bolt your steering wheel to the adapter and then put the retaining nut on then the new center cover.
Old Nov 28, 2006 | 11:45 PM
MadMikeZ28's Avatar
Uh thanks but I do not need that info and has nothing to do with my first post.
Old Nov 29, 2006 | 12:10 AM
shnormo's Avatar
Sorry. well then I personally haven't done it.
Old Jun 12, 2010 | 01:57 AM
tam85's Avatar
on 90-92 camaro, an airbag wheel is standard. i installed camaro steering column with airbag and steering wheel for just $75
______________
wheel hub assembly | tammy beede at hotmail
GetReady
Aug 28, 2014 12:11 AM
Bas Jussen
Apr 2, 2014 02:44 AM
rockoosi1
Jun 24, 2009 08:34 AM
MadMikeZ28
Jul 20, 2008 04:32 PM
microkid
May 15, 2007 11:11 PM
