What can a stock differential take?
Old Feb 7, 2007 | 03:40 AM
GodNero78's Avatar
Default What can a stock differential take?
How much Horse Power and Tourqe can the stock differential of a '88 base trim (V6) take? Since I am looking into putting a 403 in i was curious if the differnetial will take the power it will be putting out (some where in the area of 300hp not sure though). Thanks in advance.
Old Feb 7, 2007 | 09:00 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default RE: What can a stock differential take?
if its a 403 with only 300 hp, thats an awfully low number. i know that the rear ends can be broken with a 350 with just a cam, manifold, and headers if you arent careful. i dont know if the v6 cars are weaker, but i doubt it. if anything, that would last longer because it woudlnt have been subjected to as much abuse for 19 years.
Old Feb 12, 2007 | 03:31 AM
Isphius's Avatar
if its a 403, like a brand new motor from summit or somewhere, it is probably built for torque. And no I dont think the stock axle will take that. The v6 axle is a good choice tho because they came with higher gears i think
Old Feb 12, 2007 | 06:29 PM
nzink's Avatar
your stock 10 blot will easily hold up to 300 hp, but as microkid said that isnt puttin out much hp with that 403. i still have my stock 10 bolt with 342 gears, and my car puts out near 400 hp, i havent had any problem with it drag racing with slicks even. If you wanted to change to a 12 bolt or ford 9 inch you will have to get rid of the torque arm setup though.
Old Feb 13, 2007 | 12:27 AM
GodNero78's Avatar
Well the 403 i am throwing in is a '79 Olds and i was curious if am gonna have to get another rear end or not though i belive (not positive) i will have to shorten the Driveshaft or find one that fits.
Another question what would i have to change the Shaft and Rear end if I am using a TH400?
Old Feb 14, 2007 | 03:17 PM
GodNero78's Avatar
Well the guy i am buying it from came by the Station last night said if i needed it he'd just give me the drive shaft along with it. Thanks for the info on what the diff would take though i am glad that will be one less part to buy
mlopezart
Feb 24, 2012 12:20 PM
ctboy
Dec 2, 2007 05:14 PM
96Camaro3800II
VS
Aug 17, 2006 01:21 PM
Midnight Falcon
Jan 23, 2006 10:25 PM
