Taking starter off 305 TPI?
Old Feb 13, 2007 | 12:12 PM
digiti's Avatar
Default Taking starter off 305 TPI?
[align=left]I need to take the starter off my 305 TPI '91.. What's the easiest way to go about this? From underneath? Pictures anyone?
[/align][align=right] [/align]
Old Feb 13, 2007 | 11:53 PM
cubancamaro's Avatar
Default RE: Taking starter off 305 TPI?
to take your starter off theres only two bolts. get in from the bottom and theres a long bolt on the left and short on the right depending on how your looking at it. make sure to take the negative off your battery so you wont get zapped it aint pretty. take the wires off and your done. the wires are pretty much dummy proof, the big circle connecters go on the big bolt and the little one goes on the small bolt looking one. anyway make sure to take your starter to advance auto parts in your area to get tested. i had the same problem and it wasnt my starter it just turned out that my wires werent getting good connection and or i had to let my fuel pump circulate before i can start it because it was drawing power all at the same time. just let me know how it turns out when your done but its pretty easy man nothing hard about it.
Old Feb 14, 2007 | 12:36 PM
digiti's Avatar
I'm just going to take it off, clean everything up, and seal everything so no moisture gets into it.. Should fix the problem
Old Feb 14, 2007 | 03:29 PM
superhotchevy's Avatar
cubancamaro pretty much nailed it on the head. I got one of those light weight racing starters that are adjustable and fully rebuildable. It totally kicks a**. I barely have to turn the key!!
YoungDriver
General Racing/Tech
Jun 21, 2009 10:04 PM
350rs
Apr 30, 2009 04:53 PM
kyleengert
Jun 3, 2008 03:21 PM
superROB23
Aug 15, 2007 06:06 PM
ahlers
Sep 29, 2006 06:48 PM
