Turn Signal Problem
Old Jul 28, 2010 | 09:13 PM
yankeeboy's Avatar
Default Turn Signal Problem
Hi, the contact pins in the passenger side turn signal socket have corroded. The bulb doesnt get a good connection and every time i hit any bump or pot hole, it causes the signal to act as if the bulb has blown. Is there somewhere along the harness where the turn signal connects via a connector to the main wiring loom of the car? Or will I have to cut and connect a new socket/bulb holder?
Old Jul 29, 2010 | 07:41 PM
microkid's Avatar
March 2011 ROTM
Technical User
you will have to replace the socket, which any auto parts store should have. you will have to cut it. my advice is to get the shrink tube butt connectors. they are 100% waterproof connections that wont corrode
Old Jul 29, 2010 | 10:21 PM
yankeeboy's Avatar
Thanks, I'll have a look round tomorrow
Old Jul 30, 2010 | 11:54 PM
91camaro350's Avatar
best idea is if ur going to change it anyways get led bulbs last alot longer and are nicer the stock i changed mine over and the work awsome
Old Jul 31, 2010 | 08:08 PM
yankeeboy's Avatar
Will do, any idea where i can get them? Autozone or will any parts store have them?
Old Aug 1, 2010 | 07:16 AM
ya any parts store
Old Aug 1, 2010 | 07:49 PM
microkid's Avatar
March 2011 ROTM
Technical User
they just will make your blinkers go insanely fast unless you get the ones with a load ballast or swap to a digital blinker
Old Aug 2, 2010 | 08:29 AM
they dont mine mine blink just like stock does just bright as ****
Old Aug 3, 2010 | 03:06 PM
yankeeboy's Avatar
Thanks for the suggestion, worked great! No problem with the flash pattern. Thanks guys!
smittty634
Feb 18, 2012 07:09 PM
bezerker
Jul 11, 2010 07:59 PM
adamcc91
LS Series Tech
May 10, 2010 04:40 PM
Jwh22586
Jan 7, 2010 03:06 PM
02StanGT
Sep 3, 2007 08:20 PM
