Turn Signal Problem
Old Dec 27, 2009 | 12:39 AM
Jwh22586's Avatar
Default Turn Signal Problem
My rear turn signals and hazard lights work but my front ones don't. Both of my lights work. Both of my indicators work on the dash. Anybody have suggestions on where I should start looking. Anyone else had this problem before?
Old Dec 27, 2009 | 10:37 AM
ghostpopi's Avatar
when the flasher unit is functioning properly,an audible click can be heard during it's operation .if the turn signals fail on one side or the other and the flasher unit does not make a clicking sound ,a faulty turn signal bulb is the problem.
If both turn signals fail to blink the problem may be due to a blown fuse, a faulty flasher unit, a broke swtich,or loose or open connection.check fuse box make sure flasher fuse isn't blown an check for shorted wires.
Old Dec 30, 2009 | 12:08 AM
jc1047's Avatar
those bulbs have two sets of wire in them that make them light up for dif. things one side might have went off so i would try and get a new one and see if that fixes it
Old Jan 2, 2010 | 08:18 AM
Curt705900's Avatar
I have the same problem with my camaro, i still have to fix it, both of the front bulbs are out so im pretty sure i have to replace them. the only problem im having is getting the weather guard off.
Old Jan 3, 2010 | 01:28 PM
nosc's Avatar
The panel directly below has to be removed screws around the outter edges of it and I also had to loosen the black guard along the front to get the cover for the turn signals off.
Simplier and more cunfusing , turning a 5 minute job into a 20 minute one.
Old Jan 7, 2010 | 03:06 PM
Curt705900's Avatar
Yeah i can get every screw but just one! JUST ONE! and oddly that only one is whats keeping me from getting to my bulbs. so i gotta cut out that screw and budda bing, i should be able to replace my bulbs with no hassle. but in the mean time i must wait till this spring.
smittty634
Feb 18, 2012 07:09 PM
yankeeboy
Aug 3, 2010 03:06 PM
bezerker
Jul 11, 2010 07:59 PM
adamcc91
LS Series Tech
May 10, 2010 04:40 PM
02StanGT
Sep 3, 2007 08:20 PM
