LT1/LT4 Tech 1993-1997
turn signal problem need help
Old Feb 18, 2012 | 05:58 PM
smittty634's Avatar
Default turn signal problem need help
i have a 1996 camaro z28 all of a sudden my blinkers are not working i check the flasher wasnt that i check the fuses wasnt that so i went to the store to by a new turn signal switch and the harness does not fit my car i cant find one that does is there a way for me to bypass it so i can have blinkers for right now
Old Feb 18, 2012 | 06:23 PM
which flasher did you change? theres one under the dash and one under the hood?
Old Feb 18, 2012 | 06:26 PM
smittty634's Avatar
i changed the one under the dash
Old Feb 18, 2012 | 06:38 PM
do the 4 ways work
Old Feb 18, 2012 | 06:54 PM
check the ground on the driver side under the kick panel g200
Old Feb 18, 2012 | 06:56 PM
smittty634's Avatar
what are the 4 ways
Old Feb 18, 2012 | 06:59 PM
sorry, 4 way flashers are they working? the 96 is a bit different than mine, i think there is something i am missing.
Old Feb 18, 2012 | 07:09 PM
smittty634's Avatar
yes they are working
yankeeboy
Aug 3, 2010 03:06 PM
bezerker
Jul 11, 2010 07:59 PM
adamcc91
LS Series Tech
May 10, 2010 04:40 PM
Jwh22586
Jan 7, 2010 03:06 PM
02StanGT
Sep 3, 2007 08:20 PM
