swaping gauge clusters in a 84
Old Aug 6, 2013 | 11:37 PM
slayer13x's Avatar
Default swaping gauge clusters in a 84
my camaro has the gauge cluster that goes up to 85 mph on one side and gas on the other with 3 lights in the middle. but them only light up if theres a problem so i never know what my volts or oil temp or rpms is. is there a way to switch to a different gauge cluster that will swap right in?
Old Aug 7, 2013 | 07:01 AM
RonnieJ86's Avatar
heres instructions how to swap out the dummy light gauge to a full gauge cluster. Swapping in an IROC Gauge Cluster for a Base Model Cluster - ThirdGen.org http://www.thirdgen.org/techboard/in...atability.html the other link shows you can use the 82-89 clusters for a plug and play swap. Just make sure the sending units are changed, and if your running a V6 have a V6 cluster and same with a V8.
1987Camaro
Feb 22, 2012 02:58 PM
grabbem88
Sep 20, 2011 06:49 PM
laywezzie
Apr 4, 2010 12:44 PM
Swiftpain
Jan 9, 2010 03:41 AM
Frost
Oct 25, 2006 02:37 PM
