shift light
Old Jan 5, 2007 | 12:20 AM
microkid's Avatar
March 2011 ROTM
Technical User
Default shift light
1986 z28 305 TPI. where should i set my shift light at? the tranny, when left alone in drive, shifts at 4k, when the orange starts on the stock tach. i mostly use my car for daily driving with street racing and cruising on the weekends. i currently have it set at 4500 rpm.
Old Jan 5, 2007 | 12:51 AM
MadMikeZ28's Avatar
Default RE: shift light
If you have an automatic what is the use of a shift light...other than looking cool.
The max power is 4800 RPM so there is no reason to go over that.
Old Jan 5, 2007 | 06:05 PM
microkid's Avatar
March 2011 ROTM
Technical User
well, its not really a shift light on my tach, but a little red arrow. shift light is easier to say. i can see taking it to 5k if its a close race because then the engine is closer to max hp in the next gear
Old Jan 5, 2007 | 08:46 PM
MadMikeZ28's Avatar
ORIGINAL: microkid
well, its not really a shift light on my tach, but a little red arrow. shift light is easier to say....
I gotcha!
I know exactly what your talking about. I got a 5" monster tach to put in my mom's S10 with one of those pointers.
Old Jan 6, 2007 | 08:06 PM
microkid's Avatar
March 2011 ROTM
Technical User
haha, im hoping it has something done in order to require a monster tach. i dont even think one of them will fit in a third gen. which brings me to another question, where would a good place be to mount the tach? i have it on my old dash, barely holding onto the crappy top. i cant get the screws to go any deeper, and i tried drilling with no luck (weird angle), and i dont want to have that issue when i get a new pad
Old Jan 6, 2007 | 11:19 PM
MadMikeZ28's Avatar
What size gauges do you have? Did you happen to see the link I left to the gauges I sold? If you have the small gauges you can fit all six in there.
Old Jan 7, 2007 | 08:19 PM
microkid's Avatar
March 2011 ROTM
Technical User
the volt, oil pressure, and temp are around 1 1/2", the fuel was near 2 inches, and the tach is 3 1/2"
Old Jan 7, 2007 | 10:12 PM
MadMikeZ28's Avatar
I had the 3 3/8" tach and speedo and the rest of the gauges 2 1/8". It looks as if you need to make a panel. Are you using the stock speedo? You can maybe get a piece of aluminum and use your old bezel as a template and cut out a new one. Might look sweet.
Old Jan 8, 2007 | 07:14 PM
microkid's Avatar
March 2011 ROTM
Technical User
im not that concerned with cosmetics right now. i am using the stock speedo. the gauges wont fit in over the original plastic peice, and i dont want to cut it out because it has the circuit panel which i need for the lights around the speedo. eventually, i might cut it out, but im not sure. its at the very bottom of my list of priorities.
RCT
Sep 11, 2014 10:02 AM
us63bravo
Jun 18, 2010 01:34 PM
lt4weeda
May 8, 2010 12:46 PM
91_Camaro_RS
Nov 29, 2008 06:35 PM
marck
Aug 28, 2008 01:21 PM
