questions about 4:10 gears
Old Nov 1, 2006 | 07:46 PM
RedDragon's Avatar
Default RE: questions about 4:10 gears
we are going it build the 383
Old Nov 1, 2006 | 07:54 PM
SickSickSick's Avatar
the only thing you'll notice is it will spin a little worse than before. Sick
Old Nov 1, 2006 | 07:58 PM
gray89vert's Avatar
i have 3.73s with basically the same drivetrain as you 305, auto... imho 4.10 is way too high. i wish i had a higher gear than the 3.73's. lots of acceleration and easy to spin the tires when you want to but not practical.
Old Nov 2, 2006 | 12:17 AM
RedDragon's Avatar
gary89vert so how does your 3:73s do ya thats the main thing why I wanted 4:10 because to make it quicker and the acceleration because just romping it and some strip time and also going to stick a bigger motor in it some day I just think it would be a good building block.Ow btw how much of a difference doe a posi have little quicker or hardly noticable
Old Nov 3, 2006 | 01:38 AM
RedDragon's Avatar
ttt does anyone have anyother imput
Old Nov 3, 2006 | 03:57 AM
v8chvyguy's Avatar
Shnormo's sugg. on the auburn is an excelent one, I've installed alot of them and I really like them, they are about the best unit out there. I was going to put one in my 79 Z28 until I put a Detroit Truetrac in the front 8.5 10 bolt in my 82 3/4 ton 4x4 pickup. It's better than LSD in that it works just like a LSD, but under torque, when it senses slip, it locks like a mechanical locker. It's helical gear construction makes it bulit proof. And since it does not use a clutch pack you don't need friction modifier. My boss took this pic just after I finished the install, please note that before I could not climb this rock. I recomend this because you plan on doing a 383 later on, The Auburn is an awsome unit but that 383 will wear it out sooner than you think. The Detroit is built with high torque stress in mind and may prove to be a longer lasting choice.
LeadFarmer
LS Series Tech
Feb 11, 2010 04:12 PM
chewybacca11
Dec 16, 2009 02:13 AM
BigNic
Feb 7, 2008 01:25 PM
1bad96Z28
Jun 9, 2007 09:12 AM
sammyrocker5150
Dec 16, 2006 03:03 AM
