question about electric fans
Old Oct 11, 2008 | 04:59 PM
mtn_maro's Avatar
Default question about electric fans
ok so when i owned my jeep a common thing to do was replace the mechanical fan with an electric fan from a taurus and it was supposed to give you more power. the only thing i figured that would make it hold true was it would take the load off of the crankshaft and put it on the alternator thus decreasing how much the engine itself needs to turn. would that make sense? because if this is the case then i plan to put an electric fan on my z28. ill probably do it anyways but all the same.
Old Oct 11, 2008 | 07:23 PM
MadMikeZ28's Avatar
Default RE: question about electric fans
You got an 87? The last year for carbs. The last year for the Vbelts or semi serpintine.
When I installed a serpintine kit on my 84 I had to use an e-fan because it has a reversed direction on the water pump and the only thing I could think of that had a fan on that type system was a pick up. So I left my shroud on a put the biggest e-fan inside it and two smaller pushers on the a/c condesor that came on when I switched on the a/c.
Old Oct 12, 2008 | 02:07 AM
mtn_maro's Avatar
ORIGINAL: MadMikeZ28
thanks. and yeah i got an 87. this winter im going to try and swap it to tbi. but it all depends on money and time. i should be able to pull it off. im pretty handy with wiring and ive been working on cars since i was 9. so other than every now and then having a dumb question because i didnt even try to think i normally get around
camaroman67401
May 24, 2009 09:10 PM
1fastVelle
Feb 2, 2008 01:48 AM
tmroesle
Feb 19, 2007 02:36 AM
bowtieguy
Sep 23, 2006 10:19 PM
narlyman13
Sep 8, 2004 03:44 PM
