electric fans
ok so im going nuts here i bought a 92 rs camaro with the 305 tbi in it about two years ago. it would never get up to temp so i changed the thermostat in it and now it will get up to temp but warms up way to much but will not cool down so i replaced the electric fan and relay i could get the fan to kick on with the ac switch on but now i cant get the fans to kick on period. anyone care to take a stab at it?
Yeah all the fuses are good. im not understanding why it worked at first but not after about two weeks. could it of burnt up the relay or fan again?
any ses light come on? have u checked for trouble codes? get the test light out and see if power is getting to the fan or the sensor. well u could run a small hot and ground wire to the plugin on the fan and see if it comes on. its best to do it rihgt but u could hook up a manual switch so u can turn the fans on when u want.
test the relay and see if your gettting juice to it. i read that another guy on here got one that was not good quality and it went out in short order. are u sure the thermostat is in the right way and is the right one for your car. not sure if its an issue with the 305 but is there bleeder valves in the coolant system. could be air lock.
well theres nothing on the water pump on mine and with this being a different set up. im honestly tired of fooling with this damn thing im about to get rid of it and buy a 97 Z28 with ttops.......no one knows where this damn switch is even though it "does exsist" unless you talk to the kid at auto zone then there isnt one on mine...even though the fans dont work without it
